Guest deborahjayne Posted March 13, 2004 Share Posted March 13, 2004 could someone please help me.I have a optima rf wieless alarm and every time i enter my house and the pir picks me up the bell goes off outside.How can I stop this. Link to comment Share on other sites More sharing options...
geov Posted March 13, 2004 Share Posted March 13, 2004 could someone please help me.I have a optima rf wieless alarm and every time i enter my house and the pir picks me up the bell goes off outside.How can I stop this. Hi D-J, looks like the detector has been incorrectly programmed as an "alarm" zone rather than "walk-through". Has this fault only recently started or has it existed since system was installed? The installing engineer (presuming u did not install yourself) should be called back to reprogramme the system. If you did install yourself then check the programming section of the installation manual on how to correctly programme the troublesome zone. Regards, George Link to comment Share on other sites More sharing options...
Guest RICHL Posted March 13, 2004 Share Posted March 13, 2004 Or you're using the wrong door. Link to comment Share on other sites More sharing options...
j.paul Posted March 13, 2004 Share Posted March 13, 2004 Or you're using the wrong door. Or the door contact on the door dose not work (flat battery etc) jpaul There are no stupid questions, but there are a LOT of inquisitive idiots. Link to comment Share on other sites More sharing options...
Guest deborahjayne Posted March 13, 2004 Share Posted March 13, 2004 Thanks george. This problem has only started recently.We had someone to install the system and am trying to get hold of him with some difficulty.We have looked at the instructions of the booklet.It says change it back to factory mode but it wont do it. Link to comment Share on other sites More sharing options...
Red Fox UK Posted March 13, 2004 Share Posted March 13, 2004 Or you're using the wrong door. Or the door contact on the door dose not work (flat battery etc) jpaul More than likely.... Red Fox | Hosting Affordable and Reliable UK Based Web Hosting Link to comment Share on other sites More sharing options...
Guest lev Posted March 14, 2004 Share Posted March 14, 2004 The optima RF by default is set for Zone 1 Entry/Exit Zone 2 Time Inhibited Zone 3 -5 Immediate It is unclear if the internal alarm is sounding as well If so, you can bet that zone 1 is not working and walking into zone 2 will sound the alarm or zone 1 is going to tamper because of a loose lid. If you haave a low battery on zone 1 this will be indicated when you arm the panel by entering your user code e.g zone 1 will be lit and low battery light. regards Link to comment Share on other sites More sharing options...
geov Posted March 14, 2004 Share Posted March 14, 2004 Thanks george.This problem has only started recently.We had someone to install the system and am trying to get hold of him with some difficulty.We have looked at the instructions of the booklet.It says change it back to factory mode but it wont do it. D-J, I agree with the other comments about it most likely being a fault on the main entry/exit transmitter. If you can advise what is showing on the control panel (apart from alarm notification), this may confirm a low battery/ tamper fault. If you advise re. the above and/or what part of the country you are in, there is a good chance someone in the Forum can help (or "know a man who can"). Regards, George Link to comment Share on other sites More sharing options...
Guest fergmeister Posted March 15, 2004 Share Posted March 15, 2004 To anyone who can help, I have an Optima 2 Plus home alarm which is on the blink (no pun intended). There is now a continuous bleep from the keypad and the keypad itself will not accept either our personal code or the factory code. I have been advised that the battery in the control panel is probably dead but that, if i try to replace it myself, it could set the alarm off and I may not be able to reset it. Q. Does this type of system have a tamper protection and if I try to replace the battery will it trigger our alarm? What should I do (other than call-out an engineer)? , Fergmeister Link to comment Share on other sites More sharing options...
Guest simmo Posted March 15, 2004 Share Posted March 15, 2004 Sounds like your panel is locked out. Opening the panel will activate the tamper simply entering your user code will silence this. If the keypad is not responding remove mains power from the panel (use the fuse in the fused spur) and disconnect battery. Your external sounder should operate when power is removed ignore this for now. Reconnect mains then battery. (Make sure the battery is ok - if in doubt get a new one). Hopefully all should now be well. If the panel has defaulted I believe the default code is 0123 but I stand corrected if I'm wrong. If you are in any doubt about what you are doing get somebody in that does. Post your location and we can find someone local to you. It might not be as expensive as you think. Simmo B) Link to comment Share on other sites More sharing options...
