Guest Dan Posted November 27, 2003 Share Posted November 27, 2003 Hi , I would appreciate any tips on what may be causing a false alarm on one particular zone with 3 Shock sensors (GS613 with reed). I have an Aritech panel (CS 350) and the same zone keeps reporting a G3 alarm. I have verified all the wiring , EOL resistor etc, but it keeps happening. Can Shock sensors be faulty ? Regards, Dan Link to comment Share on other sites More sharing options...
Service Engineer Posted November 27, 2003 Share Posted November 27, 2003 Any Detector can go faulty, have you tried bypassing each one, one at a time so you can determine which one is playing up. ........................................................ Dave Partridge (Romec Service Engineer) Link to comment Share on other sites More sharing options...
Guest Racer25 Posted March 11, 2004 Share Posted March 11, 2004 Hi I am try to get a hold of a manual for the CS 350 as we have a very similar problem and until an engineer calls plan on inhibiting the 2 sensors that are faulty. Thanks Rob Link to comment Share on other sites More sharing options...
