Guest Rocky Posted November 6, 2003 Share Posted November 6, 2003 On the Abacus 8 system... If the 'Push To Set' button is pressed whilst the exit device (in this case a C100 dualtech) is still active (with the internal sounder emitting a bleeping tone to indicate an open zone as expected), does the system register a bad set? A client is experiencing bad set problems but I suspect they are not allowing enough time for the detectors to close out (i.e. they're not waiting for the internal sounder to emit a constant tone) before they're pressing the 'Push To Set'. What do ya think? Link to comment Share on other sites More sharing options...
Service Engineer Posted November 6, 2003 Share Posted November 6, 2003 Im not too familliar with the Abacus 8, but cant you enable a setting delay to overcome the problem..? ........................................................ Dave Partridge (Romec Service Engineer) Link to comment Share on other sites More sharing options...
