June 21, 200521 yr comment_57931 Yes, I know it's old (very,1968) but I still need the user manual, well, page two only, the one showing how to change the user code, or Keycode as Shorrock call it. It's in section 2.1.3, I've got all the rest but this page got ripped at sometime in the past and I'm missing the top half, too many bits of paper in the same box, and the bit I want has gone! If anyone has these details I would be very grateful, magpye Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 21, 200521 yr comment_57934 Hi Magpye, I work for Initial and even I havent got a manual on that thing. I will try and get the info tommorrow for you off some of the old timers.They may be old but there is still a few of them out there. I had the pleasure on sunday after the lightning of trying to prog one (without the manual). Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-57934 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 21, 200521 yr Author comment_57935 PJF, thanks for that. By the way, I'm one of the 'old timers' been at it for 30yrs+, ask your guys if any remember the Model 88, 89 or 91 Tele-Alarm, SID 27s Seismic Detector or 23p PSU (got the paperwork for these!!!!!) magpye Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-57935 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 21, 200521 yr comment_57996 I'm not 100% but isn't it code # and then new code??? try it Quote of the day: A good friend will bail you out of jail but a true friend will be sitting next to you saying damn we fcuked up!!! management treat us like mushrooms!! keep us in the dark and feed us bullsiht!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-57996 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 200521 yr Author comment_58019 kgilly, thanks for that, sounds right but, I'd rather know, best to ring the customer with 'do this' rather than 'do this, see if it works', if you see what I mean. magpye Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58019 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 200521 yr comment_58092 I am sure it is Code #. It is * to isolate zones.. The 1500 didnt have any programming to it. It was all done via cutting resistors or links on the main PCB. The only thing you can programme via the keypad was the codes. One of the easier Shorrock panels. Try doing the 1600 not the KS1600 with out a programming card. Now thats fun. Kev Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58092 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 23, 200521 yr comment_58194 i'm gathering you never see a shorrock 72 4 zone panel keyswitch or the one with the solinoid so you can't turn the keyswitch to on while the system is in fault??? Quote of the day: A good friend will bail you out of jail but a true friend will be sitting next to you saying damn we fcuked up!!! management treat us like mushrooms!! keep us in the dark and feed us bullsiht!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58194 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 23, 200521 yr comment_58199 Magpye, I havent forgot. Im meeting an engineer at the office tomorrow and he has a reference card that shows how to prog a 1600. He did try to explain over the phone but it seems a bit long winded. I will post tomorrow PJF Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58199 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 23, 200521 yr Author comment_58200 Well, I'm sorry, could not think of the model number for one of those, know how to fix them though, take the covers off the relays and give them a good blow - if they ever went wrong that is. Once installed a multicircuit, about 8/10 boxes (100 or so cts.)with great big rotary switches for isolation etc, and two 'pea' bulbs to each circuit. If I hunt hard enough, I might even have some paperwork if any one needs it for fault finding!!!!! - I bet it would still work today even after 25+ years. how many of todays panels will be working in 25+ years, not many, if any. magpye ps Who renmembers the old Acorn control panels from, I think, Cornwall. Both battery only and a mains version? Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58200 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 23, 200521 yr comment_58205 I think that Ive heard of the acorn panels, did they come in wooden boxes and only had a key switch on the front. Some of the old stuff was built to last, apart from not liking surges,lightning etc they seem to last 15+ years no problem. I have spent many a happy couple of hours trying to fix the latter model shorrocks & securicor panels, most of them do tend to come back to life and stay ok. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/6541-old-shorrock-1500/#findComment-58205 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
