Dark edges on CCTV image at Wide Angle - Normal?
What you are seeing here is classic optical and mechanical vignetting, and it is a very common headache when pairing budget varifocal lenses with modern 4K/UHD image sensors like the Sony IMX317.
The fact that the dark corners disappear completely when you zoom into 10mm–12mm confirms beyond doubt that the sensor's diagonal corners are clipping outside the usable image circle projected by the lens at wide focal lengths.
Here is the physical breakdown of why this happens on that specific setup, and how to resolve it:
  1. The 16:9 Aspect Ratio vs 4:3 Image Circle Mismatch:
  2. The Sony IMX317 is a native 16:9 4K sensor (active area approx 6.28mm wide x 3.53mm high, with an optical diagonal of 7.20mm). Many budget generic lenses (such as unbranded ELP 2.8-12mm units) stamped with '1/2.5"' are actually computed around older 4:3 aspect ratio sensors. On a 4:3 sensor, the horizontal width is narrower. Because the 16:9 IMX317 is significantly wider horizontally, its far corners extend into the extreme periphery of the lens's projected light cone where the image circle collapses.
  3. 2. Flange Back Focal Distance (The 5mm C/CS Mount Trap):
  4. You mentioned it is a 'C mount' lens. Standard C-mount lenses have a flange focal distance of exactly 17.526mm, whereas CS-mount camera bodies have a flange focal distance of 12.526mm (exactly 5mm shorter).
  5. If the camera body has a CS-mount back-focus thread and you screw a C-mount lens directly onto it without the required 5mm spacer ring, the rear glass element sits 5mm too close to the sensor. While you may still achieve close-focus by turning the focus ring, the steep angle of light rays exiting the rear group at 2.8mm will physically clip against internal barrel housings. Conversely, check if the camera already has a 5mm threaded collar installed between the lens and body that shouldn't be there.
  6. 3. Back-Focus Collar Adjustment:
  7. Most CS-mount board cameras have a rotatable back-focus collar on the camera chassis locked by a tiny grub screw. If the back-focus distance is misaligned, you will get severe barrel shading at the wide end while struggling with focus across the zoom range. Loosen the set screw, set the lens to infinity, zoom to 12mm to find crisp focus, then zoom out to 2.8mm and adjust the camera's back-focus ring until the center and edges sharpen up.
  8. 4. Natural Cosine-Fourth ($cos^4\theta$) Falloff & Aperture Shading:
  9. At 2.8mm wide angle on a budget lens without aspherical optical elements, natural optical falloff causes illumination at the corners to drop significantly compared to the center. If the manual iris ring is wide open (e.g. f/1.4), the internal iris blades physically vignette oblique rays. Closing the iris down slightly to f/2.8 or f/4 will often sharpen the periphery and reduce the dark shading substantially, provided you have adequate ambient lighting.
  10. 5. The Professional Field Solution:
  11. If you need a true 2.8mm wide-angle field of view on a 1/2.5" 16:9 sensor without dark edges, the industry standard practice is to use an oversized lens format — specifically a 1/1.8" or 1/2" rated lens (such as Computar, Fujinon, or Kowa). A 1/1.8" lens casts a larger 9.0mm image circle, meaning the IMX317 sensor sits comfortably inside the sweet spot center of the glass with zero corner vignetting and far better edge-to-edge sharpness.
