Navigator Posted May 9, 2021 Share Posted May 9, 2021 I have a partitioned system and I want to add an internal sounder to one of the partitions. I know that I can connect it into the same terminals as the external sounder but I only want to have it activated in a specific partition. I can configure it in the Wired Outputs as a siren but I'm unsure of the PCB connections. I want to use a Kinetic Quad Piezo Sound Bomb Internal Sounder KSB2 Can anyone help me? I've attached a diagram of the PCB layout if this helps. Thanks. Quote Link to comment Share on other sites More sharing options...
Monty Posted May 9, 2021 Share Posted May 9, 2021 Use the out puts and progg to follow partition not sure how much current your sound one draws possible use smart relay just in case Quote www.AllanMoncrieffAlarms.com Link to comment Share on other sites More sharing options...
Navigator Posted May 15, 2021 Author Share Posted May 15, 2021 Thanks @Monty for taking the time to reply. All connected and working Quote Link to comment Share on other sites More sharing options...
