James R Posted November 30, 2020 Share Posted November 30, 2020 Hi all, Have a galaxy install where no door contacts have been specced - so unable to start setting/unsetting from a zone - set the dt pir at the front door lobby to EXIT and was wondering how best to set up the system for the customer - with timers for setting/unsetting? Regards Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44247-set-up-for-galaxy-with-no-door-contacts-specced/ Share on other sites More sharing options...
The Arab Posted November 30, 2020 Share Posted November 30, 2020 I would have thought you'd do the first detector as entry, then time set would be enough time to allow the detector to settle say 30 seconds then it depends how far keypad/prox is from the detector so say 20-30 seconds Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44247-set-up-for-galaxy-with-no-door-contacts-specced/#findComment-506789 Share on other sites More sharing options...
James R Posted November 30, 2020 Author Share Posted November 30, 2020 30 minutes ago, The Arab said: I would have thought you'd do the first detector as entry, then time set would be enough time to allow the detector to settle say 30 seconds then it depends how far keypad/prox is from the detector so say 20-30 seconds Sorry yes first dt is set to entry (exit is the one to be used with a push button?) Yeah, think 30 secs for the timer on setting - kp is in the entrance lobby and the dt is in the lobby set to ENTRY. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44247-set-up-for-galaxy-with-no-door-contacts-specced/#findComment-506790 Share on other sites More sharing options...
