Keith p Posted January 13, 2019 Share Posted January 13, 2019 Hi I have a 9448ES alarm system , I set off the zone 6 which is set to panic alarm which has now lit up red on the 9427 control pad, how do I reset it so that the light goes off please Thanks Keith p Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 13, 2019 Share Posted January 13, 2019 30 minutes ago, Keith p said: Hi I have a 9448ES alarm system , I set off the zone 6 which is set to panic alarm which has now lit up red on the 9427 control pad, how do I reset it so that the light goes off please Thanks Keith p Ok but where is your panic switch? Just use key to reset it Or your trying to say another type of sensor is connected here and now says panic Or you got little confused so go look for panic switch if you don't have key you could open it and manually reset it Or your doing some DIY on alarm? More detail needed Quote Link to comment Share on other sites More sharing options...
Keith p Posted January 13, 2019 Author Share Posted January 13, 2019 Thanks ks sorted it now didn't realise you Had to turn the key Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 13, 2019 Share Posted January 13, 2019 1 hour ago, Keith p said: Thanks ks sorted it now didn't realise you Had to turn the key Cool dude , some old ones snap the mechanism or plastic keys break aswell Quote Link to comment Share on other sites More sharing options...
