Adding PIR to Enforcer v10
Would appreciate some guidance. Adding a KX10DP-WE to an enforcer panel, no problem with the learning and set as Intruder input but doing walk test does not trigger a pass, also blue light does not flash on proximity movement. Help!
25 minutes ago, petrolhead said:
A,b,c,d
Also you have to exit engineer mode before walk testing a new device.
Programming manual wasn't clear on this but I worked it out OK. Nice system, quite impressed. Early days but cloud works well.
