Chopper81 Posted December 4, 2014 Share Posted December 4, 2014 Hi Guys (and girls) Im swapping out a px500 for galaxy dimension. Ive no problem with programming the zones etc but the current px500 is connected to the dualcomm by the dial capture feature. This is something im not massively familiar with. Everytime ive used a communicator (digi dual redcare or emizon) ive done the programmed outputs to the pins on the communicator. How does the dial capture work? As it is at this moment in time the A and B terminals on the px500 are wired to the a and b terminals on the dualcomm, theres a plug on board on the dualcomm woth the phone line wired in and fire is signaling on pin 1. I assume that i just copy the existing with reagrs to galaxy a and b to dial capture on the redcare but do i need to change any settings on the galaxy i.e. format tele number etc or is all that done through the dualcom. Any help would be fantastic * dial capture on the dualcomm i meant Quote Link to comment Share on other sites More sharing options...
9651 Posted December 4, 2014 Share Posted December 4, 2014 http://www.thesecurityinstaller.co.uk/community/topic/37781-px500-swap-out-dualcomm-query/ ? Quote Link to comment Share on other sites More sharing options...
Chopper81 Posted December 4, 2014 Author Share Posted December 4, 2014 Apologies I accidently posted this in the regs section but meant it for here. Subject is probably more suired to this section. Quote Link to comment Share on other sites More sharing options...
