Dan24 Posted May 27, 2013 Share Posted May 27, 2013 I've got an Axis M1031-W and have set it up on the same network as the DS2, but I can't seem to get either to connect. Does anyone have a trick to getting the DS2 to pick up the feed from an Axis cameras? I'm sure there's a setting which needs changing on the camera menu. They're on the same Ethernet module on the same router, but I haven't set up port forwarding. Thanks, Dan Link to comment Share on other sites More sharing options...
Mattodare Posted June 1, 2013 Share Posted June 1, 2013 Don't believe the M1031 is supported, pulled the following 'supported' cameras from DMs site Axis206, 207, 211, 211A, 213, 214, 221, 223M*, 225FD, 2120, 241Q, M1054 Link to comment Share on other sites More sharing options...
