Guest pkh911 Posted August 15, 2004 Share Posted August 15, 2004 Well Said Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2004 Share Posted August 15, 2004 Call Elmdene in portsmouth they supply sealed contacts, we have to use them here in IrelandBest Regards Phil Hayes 20427[/snapback] nothing guards against dogs & drunks p*** its acidic you know Link to comment Share on other sites More sharing options...
Brian c Posted August 15, 2004 Author Share Posted August 15, 2004 Call Elmdene in portsmouth they supply sealed contacts, we have to use them here in IrelandBest Regards Phil Hayes 20427[/snapback] nothing guards against dogs & drunks p*** its acidic you know 20431[/snapback] he he he If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest pkh911 Posted August 15, 2004 Share Posted August 15, 2004 Start as you mean to go on. install to EN Standards now. We (Sparks Security Systems) Ireland, have been accredited to EN50131. On the other point Ademco certify thier equipment to ALL new grades. So too do a company in Ireland called HKC thier panels are FULLY compliant Best Regards Phil Hayes Link to comment Share on other sites More sharing options...
Brian c Posted August 15, 2004 Author Share Posted August 15, 2004 ok phil thanks for your comments If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest pkh911 Posted August 15, 2004 Share Posted August 15, 2004 Sorry Eng thought standards were european wide. We HAVE to install to EN50131 in ROI or we cant issue certs Best Regards Phil Hayes Link to comment Share on other sites More sharing options...
Guest pkh911 Posted August 15, 2004 Share Posted August 15, 2004 No Probs Matey Link to comment Share on other sites More sharing options...
Guest Guest Posted August 15, 2004 Share Posted August 15, 2004 We HAVE to install to EN50131 in ROI or we cant issue certs What equipment are you using and how have found the transition from one standard to the other? Link to comment Share on other sites More sharing options...
Brian c Posted August 15, 2004 Author Share Posted August 15, 2004 oh, 1 more question. can i use a detector's cable for a j.b tamper? If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest pkh911 Posted August 15, 2004 Share Posted August 15, 2004 We only use Ademco panels that where originally IS199 conformant and Elmdene HS500 Bell boxes. I wouldnt be surprised if UK adopts Irish ideas of sealed contacts. I thought the irish were the backward race (no offense intended) but we seem to be leading the way in implementing the new standards now. By the way I used to live & work in Cyprus for a Cypriot company Standards WHAT standards!!!!! Regards Phil Link to comment Share on other sites More sharing options...
