Cable Requirement
daubs8
Sounds like you've made a killing on the cable ( not in the practical sense ), so I would stick with the 2.5mm, it could always be extended then. 4 x 1amp 24vac psu's won't draw much mains currant anyway and a small voltage drop would not be a problem for these psu's.
You'll be on a beach in no time!
Ta m8. Forget the beach. I had
