Herman Posted April 16, 2008 Share Posted April 16, 2008 Under what prerequisite is a NACOSS certificate issued? Should all rooms have detectors? Should all exterior doors have contact switches fitted? Should the main panel be steel? Should the property have an external sounder (bell box)? Link to comment Share on other sites More sharing options...
BUSTER Posted April 17, 2008 Share Posted April 17, 2008 Under what prerequisite is a NACOSS certificate issued?Should all rooms have detectors? NO Should all exterior doors have contact switches fitted? NO Should the main panel be steel? NO Should the property have an external sounder (bell box)? NOT IF MONITORED A RISK ASSESSMENT WOULD DECIDE WHAT EQUIPMENT AND GRADE THE SYSTEM WOULD BE Any comments / opinions posted are my opinion only and do not represent those of my employer or Company Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted April 17, 2008 Share Posted April 17, 2008 Under what prerequisite is a NACOSS certificate issued?Should all rooms have detectors? Should all exterior doors have contact switches fitted? Should the main panel be steel? Should the property have an external sounder (bell box)? sounds like you`ve got an issue ? Link to comment Share on other sites More sharing options...
