mikepatty77 Posted June 23, 2007 Share Posted June 23, 2007 I wonder if someone can help me please, I have moved into a propery and was left instructions to use the alarm and the omit functions for use at night. The problem is that when using both functions, the alarm, when set continues to beep and doesn't switch itself off. I have placed my hand in front of the sensors and they are working when the alarm is set, but I am wondering is there anything that I can do make sure that the alarm times out and I am able to use this. Many Thanks Mike Link to comment Share on other sites More sharing options...
barooga Posted June 23, 2007 Share Posted June 23, 2007 I wonder if someone can help me please, I have moved into a propery and was left instructions to use the alarm and the omit functions for use at night.The problem is that when using both functions, the alarm, when set continues to beep and doesn't switch itself off. I have placed my hand in front of the sensors and they are working when the alarm is set, but I am wondering is there anything that I can do make sure that the alarm times out and I am able to use this. Many Thanks Mike Make and model?? Growing old is mandatory, growing up is optional Link to comment Share on other sites More sharing options...
mikepatty77 Posted June 23, 2007 Author Share Posted June 23, 2007 Make and model?? all i can see on the front of the alarm panel is that it is Optima xl4 microprocessor. is there anywhere else i can confirm which model it is? Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted June 23, 2007 Share Posted June 23, 2007 I wonder if someone can help me please, I have moved into a propery and was left instructions to use the alarm and the omit functions for use at night.The problem is that when using both functions, the alarm, when set continues to beep and doesn't switch itself off. I have placed my hand in front of the sensors and they are working when the alarm is set, but I am wondering is there anything that I can do make sure that the alarm times out and I am able to use this. Many Thanks Mike Hi Mike and welcome to the forum , with you saying youve jsut moved into the property have you thought about getting the system checked out profesionaly and also changing the code number - it may still be posible to charge the vendors if there is a fault found angus Link to comment Share on other sites More sharing options...
mikepatty77 Posted June 23, 2007 Author Share Posted June 23, 2007 Hi Mike and welcome to the forum , with you saying youve jsut moved into the property have you thought about getting the system checked out profesionaly and also changing the code number - it may still be posible to charge the vendors if there is a fault found angus apologies, i should have said that the property is about 8 years old..... it would appear that the alarm is working....although i am no expert.... its just when set it doesn't time out as i would expect Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted June 23, 2007 Share Posted June 23, 2007 apologies, i should have said that the property is about 8 years old..... it would appear that the alarm is working....although i am no expert....its just when set it doesn't time out as i would expect if youve just bought it .................? silly question time but how long are you leaving it before you decide it hasnt set and what happens if you open then close the " exit door " and wait for 10 - 20 secs Link to comment Share on other sites More sharing options...
mikepatty77 Posted June 24, 2007 Author Share Posted June 24, 2007 if youve just bought it .................?silly question time but how long are you leaving it before you decide it hasnt set and what happens if you open then close the " exit door " and wait for 10 - 20 secs if i stand outside the exit door i can still hear it continuing to beep, waiting for it to go off, the same as when i omit one at the top of the stairs before i go to bed.....it just continues to beep....i have left this for at least a few minutes Link to comment Share on other sites More sharing options...
FASTCAR Posted June 24, 2007 Share Posted June 24, 2007 Hi , when it is beeping , is it showing one of the zones open , like zone 1 , if so it will not set.Is it possible you still have a protected door / window open?, maybe a damaged contact. Regards. Link to comment Share on other sites More sharing options...
