Guest christophlad Posted October 29, 2006 Share Posted October 29, 2006 Hi, I'm trying to wire a 660 speech dialler into a Scantronic 9651 panel without much luck. Do I need to use a relay? The 660 inputs are: 0v 12v st+ st1 st2 st3 st4 Link to comment Share on other sites More sharing options...
camerabloke Posted October 29, 2006 Share Posted October 29, 2006 no! Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
Guest christophlad Posted October 29, 2006 Share Posted October 29, 2006 Where am I going wrong then? I've got op3 on scanny panel connected to input st3 on 660. The dialler keeps trying to dial out when I do this as soon as I connect op3 Link to comment Share on other sites More sharing options...
Guest Posted October 29, 2006 Share Posted October 29, 2006 Hi,I'm trying to wire a 660 speech dialler into a Scantronic 9651 panel without much luck. Do I need to use a relay? The 660 inputs are: 0v 12v st+ st1 st2 st3 st4 Chris The 0v and 12v is power The ST+ is used to link through a relay to one of the starts eg: st1-4. If you got an output as long as it shares the 12v from the panel you should be able to program the output to intruder (or something like that) and fire the unit from o/p on panel. Sorry don't know the panel to offer further advice. Dave Link to comment Share on other sites More sharing options...
Guest christophlad Posted October 29, 2006 Share Posted October 29, 2006 Thanks for your reply Dave. I've got the 0v and 12v connected to the comms output on the panel. I had also used op3 on the board (which is defaulted to burglar signal) into st3 (which is the burglar input) on the 660. Link to comment Share on other sites More sharing options...
Guest Posted October 29, 2006 Share Posted October 29, 2006 Thanks for your reply Dave. I've got the 0v and 12v connected to the comms output on the panel. I had also used op3 on the board (which is defaulted to burglar signal) into st3 (which is the burglar input) on the 660. Give it a whirl, should be fine. Dave Link to comment Share on other sites More sharing options...
