martlewis Posted June 7, 2006 Share Posted June 7, 2006 Not sure if it's possible but can you prevent chimes being turned off at the keypad? I'm sure I've read something that said you can but I can't find it again. Can anyone help please? Link to comment Share on other sites More sharing options...
andrewjb Posted June 8, 2006 Share Posted June 8, 2006 Don't think so - I've been looking for the same feature... I'm currently considering opening the control pad and putting a bit of tape over the 'Chime' key contact ) (I don't think it's used for anything else, is it?) Alternatively, on the 48, can't you use a timer to enable chime at certain times? Maybe that could be coerced into keeping it on a lot? Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2006 Share Posted June 8, 2006 Thinking...... Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2006 Share Posted June 8, 2006 you can set an area up to auto chime when custom output a is on(see area options) but its probably less hassle just rig a buzzer up as zone follow?? Link to comment Share on other sites More sharing options...
martlewis Posted June 8, 2006 Author Share Posted June 8, 2006 I'm sure somewhere I read about forced chime. At present I'm with Andrew, disabling the button on the keypads if all else fails. Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2006 Share Posted June 8, 2006 At present I'm with Andrew, disabling the button on the keypads if all else fails. The chime button isn't just for chime, dependent on which area of programming you are in. Leave the keypad alone and do as Mr H said, output set to follow a zone. Link to comment Share on other sites More sharing options...
martlewis Posted June 9, 2006 Author Share Posted June 9, 2006 Have tried programming users, that stops them turning chime off in programming menus but anyone can press the hime button without needing a user code. As for programming needing the chime key, all my programming is via Wintex software so not an issue for me. Am going to try texecom cust support for the answer too. Will let you know what they say. Link to comment Share on other sites More sharing options...
Guest Posted June 9, 2006 Share Posted June 9, 2006 auto chime page 44 then you've got to sort out the custom output? Link to comment Share on other sites More sharing options...
martlewis Posted June 9, 2006 Author Share Posted June 9, 2006 What do you mean by single button setting? Link to comment Share on other sites More sharing options...
ranger Posted June 9, 2006 Share Posted June 9, 2006 Most panels have the abilty to set up a button (usually the set button obviously) that you can just press on its own to set the system without the need to enter your pin code. On some panels you can set up if you only want part set to be single button setting ext. Regards, Ranger The above is my personal opinion and not that of my employer or anyone else. Link to comment Share on other sites More sharing options...
