December 11, 200520 yr comment_78353 Hmmm,put it into to supervisor/access mode by putting in the code then (from memory as Im not standing in front of it) there's a button to go up an access level.Press and hold and it steps up then you press disable until it's at the required zone and change the status.That's not quite it but it's Saturday and I haven't worked on one in near two years! im not in front of the panel at the mo but once its in superviser mode i can only get it to test or disable diffrent zones, theres 5 buttons on the panel in order 1" sounders on/off 2"mute panel 3"reset 4"advance 5" select. when its in superviser mode the only option i can work out is to hold advance in and that cycles between test and disable im not in front of the panel at the mo but once its in superviser mode i can only get it to test or disable diffrent zones, theres 5 buttons on the panel in order 1" sounders on/off 2"mute panel 3"reset 4"advance 5" select. when its in superviser mode the only option i can work out is to hold advance in and that cycles between test and disable its dosnt give me the option of knocking off the disable, Link to comment https://www.thesecurityinstaller.co.uk/community/topic/8506-newlec-nl5702n/page/2/#findComment-78353 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 11, 200520 yr comment_78354 Im out, didnt realise you could issolate a zone on this panel and i dont understand re-arm. If the building is empty and the system is clearly not monitored (because if it was one would assume a maintainer) its about as much use as well its no use until people go back into the building so why worry. Re-arm as in de-isolate,but yes if it isn't monitored then leaving the detection off until next day isn't going to do any harm (unless.of course,that there is some sort of accomodation connected with the group). im not in front of the panel at the mo but once its in superviser mode i can only get it to test or disable diffrent zones, theres 5 buttons on the panel in order 1" sounders on/off 2"mute panel 3"reset 4"advance 5" select. when its in superviser mode the only option i can work out is to hold advance in and that cycles between test and disableits dosnt give me the option of knocking off the disable, Again,from memory,if you push advance to disable then select to whatever zone is isolated the LED should change staus to show if the zone is disabled or not. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/8506-newlec-nl5702n/page/2/#findComment-78354 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 11, 200520 yr comment_78376 Manual Added. MODS:- Delete If Required 61640630_issue5.pdf Dean Wholey NCC Dean.Wholey@Ntlworld.com Link to comment https://www.thesecurityinstaller.co.uk/community/topic/8506-newlec-nl5702n/page/2/#findComment-78376 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 11, 200520 yr comment_78378 Manual Added.MODS:- Delete If Required Memory not too bad then - in the right ball park! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/8506-newlec-nl5702n/page/2/#findComment-78378 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 11, 200520 yr comment_78442 Whos the original manufacture, cloride? (with an H somewhere) I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/8506-newlec-nl5702n/page/2/#findComment-78442 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
