Problems changing engineers code on Veritas R8
Guest MYT123
Guest MYT123
Yeah, changing the code is just one of the functions that I wanted to use in the programming menu but i cant seem to get access to it yet other engineering options work fine (changing timers, zone type etc).
I know it could be a lot worse but hopefully someone will have the solution and I can get my system working 100%.
MYT123
Guest MYT123
Problem sorted. Turns out its an early version of the Veritas R8, thanks to everyone for their help.
MYT123
Memory test:  Was it 08 for changing engineer code on the old ones? With 03 for misc options 1?  (high chime, sounders on tamper etc.)  :yes:
56235[/snapback]
Yes :yes:
Guest MYT123
Just to keep this thread up to date, I now have the appropriate installation/engineer manual. Thanks for all the help I've received on this matter.
MYT123 ;)
