DSC Zone Tamper
Guest gchamberlain
Valid points there (mumblemumble..nitpickingba..mumblemumble).
The same principle could be applied to the rear tamper if the switch is mounted in the same way, though.
Like i said.............if you cannot get a replacement. Replacing it will be the quickest, easiest and best solution.
If you don't know......ask.
Guest gchamberlain
Some people consider sarcasm to be the lowest form of wit, you know!
I suppose that would make me witless?
I tried stretching the spring when I took the picture. So far the tamper has stayed out. But if it gives me any more trouble, I will jumper the switch. So I can jumper either pair?
I can't disable 'tamper' in software?
Gary
Guest gchamberlain
Where is the rear tamper? On the board or on the case? Is the rear tamper supposed to indicate a board that has been removed from the case or a case that has been removed from its mounting surface? This guy is attached to the door with double faced foam tape.
Gary
Gary
43747[/snapback]
The rear tamper is on the board, and is to show if the full case is removed from the door..
I would remove it from the door, take off all the form tape, the put it back on with screws..
There are no stupid questions, but there are a LOT of inquisitive idiots.
43745[/snapback]
:D Now, I never said that! :P
43745[/snapback]
I honestly don't know, it would be trial and errror. I would say it could either pair.
Are you not able to get a replacement? It would be the best solution.
Gary
43745[/snapback]
No. I very much doubt it.
43747[/snapback]
Ah, I'd put that down as a good likely cause. First off, a couple of screws in this device, and all the other devices that are just stuck to the wall, would probably solve a few problems.
43759[/snapback]
Completely agree.
