morph Posted January 26, 2006 Share Posted January 26, 2006 And knowing how many IT experts there is on here........... Please can anyone help. 18 months ago I upgraded to Girlfriend 1.0 from DrinkingMates 4.2, which I had used for years without any trouble. However, there are apparently conflicts between these two products and the only solution was to try and run Girlfriend 1.0 with the sound turned off. To make matters worse, Girlfriend 1.0 is incompatible with several other applications, such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9. Successive versions of GirlFriend proved no better. I tried a shareware program, Slapper 2.1, but it had many bugs and left a virus in my system, forcing me to shut down completely for several weeks. Eventually, I tried to run GirlFriend 1.2 and Girlfriend 1.0 at the same time, only to discover that when these two systems detected each other they caused severe damage to my hardware. I eventually upgraded to Fianc Link to comment Share on other sites More sharing options...
PJF Posted January 26, 2006 Share Posted January 26, 2006 Nice one Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment Share on other sites More sharing options...
bri Posted January 27, 2006 Share Posted January 27, 2006 spot on Bri Link to comment Share on other sites More sharing options...
