Guest chris1971 Posted October 12, 2005 Share Posted October 12, 2005 I recently got new windows installed and now need to replace the sensors that were destroyed in the process. I have an Aritech CS350 system, I could not get the original aritech sensors but have replaced them with HKC sensors instead. I have wired the sensors as per the originals, but when I try to arm the system, it still reports thet the zones are open - can anyone help? Thanks. Link to comment Share on other sites More sharing options...
Guest IM_Alarms Posted October 12, 2005 Share Posted October 12, 2005 I recently got new windows installed and now need to replace the sensors that were destroyed in the process. I have an Aritech CS350 system, I could not get the original aritech sensors but have replaced them with HKC sensors instead. I have wired the sensors as per the originals, but when I try to arm the system, it still reports thet the zones are open - can anyone help? Thanks. When you say that you've wired them as per the originals, what would that be like then? + to + or terminal 1 to terminal 1 etc.? Link to comment Share on other sites More sharing options...
Guest Posted October 12, 2005 Share Posted October 12, 2005 Did you refit the resistors? Link to comment Share on other sites More sharing options...
Nova-Security Posted October 12, 2005 Share Posted October 12, 2005 Sounds like interia type sensors, do these sensors require power ? if not then look for the marking indication top or up direction. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
