Guest gilland Posted June 28, 2005 Share Posted June 28, 2005 Hi I have a problem with aritech cs350 - hopefully somebody might be able to help!!. I never got any manuals on installation but have never had any need for them - until now!! My house faces onto a road which has gotten significantly busier over the last while, with the result that heavier truck vibrations are setting off the sensors on my bay window. My questions are : 1)can you reduce the sensitivity settings via the key pad on certain zones? and if so - is it easy to do? Any help would be gratefully received !! Link to comment Share on other sites More sharing options...
morph Posted June 28, 2005 Share Posted June 28, 2005 If you contact the company that installed the alarm they will be able to do this for you. These forums do not give out engineering manuals. Link to comment Share on other sites More sharing options...
