Guest Bigpaddy Posted June 5, 2005 Share Posted June 5, 2005 Where would I get this video Jef? Is it downloadable? Has no one ever seen the Menvier installation video? It quite clearly shows prospective alarm engineers how easy an alarm is to wire and install. I show it to trainees as what NOT to do. Jef 55982[/snapback] Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2005 Share Posted June 5, 2005 Ive got a good suggestion.Try wireless 55941[/snapback] Link to comment Share on other sites More sharing options...
Guest daz 44 Posted June 22, 2005 Share Posted June 22, 2005 A decent pair of VDE side cutters are essential - prob one of the tools you use all the time in this trade, also a 1mm or 1.5mm slotted VDE screwdriver or terminal driver.A number 2 philips VDE screwdriver also. A decent calibrated digi meter, long 8mm and 12mm drill bits for going through walls. Also a 10mm 1meter drill bit for very thick walls you find in cottages etc or old large office buildings. 55732[/snapback] Link to comment Share on other sites More sharing options...
