August 11, 20223 yr comment_515753 Hi all Been doing alarm servicing for a little over a year now, mostly domestic with the majority of them being risco agility 2 and 3. Anyway one of our clients has an agility 2 but their keypad is playing up ( constantly draining battery's and also certain numbers are worn ) I'm just wondering if agility 3 keypads are backwards compatible with the 2 ? Basically I don't want to go all the way there just to find out it isn't only to have to hunt down for a agility 2 keypad . Any info would be much appreciated Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45244-risco-agility-2-3/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 20223 yr comment_515754 3 hours ago, Manser said: Hi all Been doing alarm servicing for a little over a year now, mostly domestic with the majority of them being risco agility 2 and 3. Anyway one of our clients has an agility 2 but their keypad is playing up ( constantly draining battery's and also certain numbers are worn ) I'm just wondering if agility 3 keypads are backwards compatible with the 2 ? Basically I don't want to go all the way there just to find out it isn't only to have to hunt down for a agility 2 keypad . Any info would be much appreciated No they are not backwards compatible you can only use the same version keypad with the panel version Let's just say I learned that the hard way Edited August 11, 20223 yr by Imnotshankled Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45244-risco-agility-2-3/#findComment-515754 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 20223 yr Author comment_515757 24 minutes ago, Imnotshankled said: No they are not backwards compatible you can only use the same version keypad with the panel version Let's just say I learned that the hard way I thought this might be the case . Thank you very much ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45244-risco-agility-2-3/#findComment-515757 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 20223 yr comment_515761 3 hours ago, Manser said: I thought this might be the case . Thank you very much ? Your welcome Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45244-risco-agility-2-3/#findComment-515761 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
