October 8, 20206 yr comment_505244 Hi, I have a old Galaxy 60 panel, V4.5 and want to install a Ethernet module. I know the new Ethernet mods don’t work on this model but some old ones do. I have been offered a V4.03 but not sure if this works. Any info would be greatly appreciated. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44138-galaxy-g60-v45/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 9, 20206 yr comment_505270 22 hours ago, Bammers said: Hi, I have a old Galaxy 60 panel, V4.5 and want to install a Ethernet module. I know the new Ethernet mods don’t work on this model but some old ones do. I have been offered a V4.03 but not sure if this works. Any info would be greatly appreciated. Thanks The new Ethernet modules should work on the older hardware, as the bus protocol has not changed. V4.03 and V4.11 will work. You'll not get the maxpro CCTV platform capability, as the older panels do not support the isom protocol in their menu system. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44138-galaxy-g60-v45/#findComment-505270 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
April 17, 20215 yr Author comment_510071 On 09/10/2020 at 08:25, GalaxyGuy said: The new Ethernet modules should work on the older hardware, as the bus protocol has not changed. V4.03 and V4.11 will work. You'll not get the maxpro CCTV platform capability, as the older panels do not support the isom protocol in their menu system. Thank you. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44138-galaxy-g60-v45/#findComment-510071 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
