Galaxy G60. V4.5
Hi, I have a old Galaxy 60 panel, V4.5 and want to install a Ethernet module. I know the new Ethernet mods don’t work on this model but some old ones do. I have been offered a V4.03 but not sure if this works. Any info would be greatly appreciated.
Thanks
Thanks
The new Ethernet modules should work on the older hardware, as the bus protocol has not changed. V4.03 and V4.11 will work. You'll not get the maxpro CCTV platform capability, as the older panels do not support the isom protocol in their menu system.
  • 6 months later...
Thank you.
