Enforcer night set programming
Hi Guys
I am having trouble with night setting my enforcer, am hoping someone can help ?
I have 4 Pir sensors in total and 4 door contacts in total all programmed in A for the full set.
I also programmed the 4 door contacts which are downstairs and 3 off the Pir sensors downstairs under B as well.
When I full set the alarm under  A the sensors downstairs did not activate the alarm when set, but the one pir upstairs did activate the alarm.
When full setting the alarm when the house is empty do I need press A and B ?
Not sure if I have made an error programming somewhere.
