September 26, 201610 yr comment_450558 I need a zone configured as a keyswitch to remotely reset via an autodialler. The zone types available don't appear to have the option only ksw bat, which doesn't do anything. The 2nd part of the zone type where you can select norm/bias is fine but can't seem to figure out how to set the system with the zone types available. I've tried it on zone 5 and zone 8 but nothing. I'm using eol and can see res change from 11k to 4k7 ok. Any advise would be good if anyone else has done this on this particular panel ve hav ze nolij or if not we ask!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40470-eurosec-cpx/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 26, 201610 yr comment_450567 Off the top of my head, I seem to remember you need to have a user code on the system set up to control the area that the keyswitch needs to set/unset (even if areas aren't used on the system!) Aslong as the above is done and the zone is programmed as normal or biased keyswitch (I think with the Monitor zone type), it should work OK. I've got one setup, I'll call in tomorrow and double check how it's programmed. Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40470-eurosec-cpx/#findComment-450567 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 27, 201610 yr Author comment_450573 Appreciate that, ve hav ze nolij or if not we ask!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40470-eurosec-cpx/#findComment-450573 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
