Castle Tech 1600 power cut problems
On 22/08/2016 at 16:08, Scott MacLeod said:
Hi,
I have 2 castle care tech 1600 alarms at my property. One is in the garage and we have never used it since moving in. We had a power cut recently and the garage alarm now has a fault condition.
The remote keypad is alarming and is unresponsive. The keypad shows power but the display is blank and keypad does not appear to respond.
I checked the battery, in the control box and it was showing 11V, battery connectors (with battery disconnected) show 13.5V. I have changed the battery and powered up but the fault condition remains. I read elsewhere that the sequence should be: mains then battery then cover which I have followed but no luck. I have checked what fuses I can see on the PCB but all is OK.
I have left the alarm with mains and battery disconnected and all is quiet. I would like to take the opportunity to bring the alarm back into use but cannot get passed the fault condition.
If anyone has any suggestions as to the problem it would be appreciated.
Thanks
Scott
Hi Scott,
did you manage to get to the bottom of the problem, mine has just developed the same issue, blank keypad, unresponsive
regards
stevie
