May 24, 20169 yr comment_446699 Need to run a cat5 externally undergound 70m ( Can be small 20mm ), what type of containment do you reccommend that's not going to cost a bomb? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 20169 yr comment_446700 https://www.tlc-direct.co.uk/Products/CACAT5EslashSWA.html?ad_position=1o2&source=adwords&ad_id=45425533757&placement=&kw=&network=g&matchtype=&ad_type=pla&product_id=CACAT5E%2fSWA&product_partition_id=74607868747&test=finalurl_v2&gclid=CPePwP7I88wCFckaGwodw60LAA just dig trench and lay in Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446700 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 20169 yr Author comment_446703 Star, thnak you! Am I right in thinking you can run normal Cat5 with SWA because the metal in armour stops EMF? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446703 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 20169 yr comment_446704 The armour is for protection not stopping EMF. should not be run together and segregated as they are different voltage bands, unless all cables are rated for the higher voltage band. all your cabling should be installed to BS7671 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446704 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
