Night Owl Posted May 24, 2016 Share Posted May 24, 2016 Need to run a cat5 externally undergound 70m ( Can be small 20mm ), what type of containment do you reccommend that's not going to cost a bomb? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/ Share on other sites More sharing options...
Simlec Posted May 24, 2016 Share Posted May 24, 2016 https://www.tlc-direct.co.uk/Products/CACAT5EslashSWA.html?ad_position=1o2&source=adwords&ad_id=45425533757&placement=&kw=&network=g&matchtype=&ad_type=pla&product_id=CACAT5E%2fSWA&product_partition_id=74607868747&test=finalurl_v2&gclid=CPePwP7I88wCFckaGwodw60LAA just dig trench and lay in Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446700 Share on other sites More sharing options...
Night Owl Posted May 24, 2016 Author Share Posted May 24, 2016 Star, thnak you! Am I right in thinking you can run normal Cat5 with SWA because the metal in armour stops EMF? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446703 Share on other sites More sharing options...
Simlec Posted May 24, 2016 Share Posted May 24, 2016 The armour is for protection not stopping EMF. should not be run together and segregated as they are different voltage bands, unless all cables are rated for the higher voltage band. all your cabling should be installed to BS7671 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40164-underground-ducting/#findComment-446704 Share on other sites More sharing options...
