Guest wesail Posted February 12, 2004 Share Posted February 12, 2004 I am looking for a quad CCTV unit that can connect to a laptop via USB or FireWire and allow the user to see all four inputs live at the same time. Anyone know where I could find such an item...? Thanks, Dave Link to comment Share on other sites More sharing options...
Guest Andyp Posted February 12, 2004 Share Posted February 12, 2004 There are CCTV digital recorders around that have a network cable (RJ45) connection. You then view the cameras through your web browser or the supplied software. Does it have to be a USB or firewire connection for any reason? Link to comment Share on other sites More sharing options...
Guest wesail Posted February 12, 2004 Share Posted February 12, 2004 Well, I'm not sure. What I'm trying to accomplish is a 4 input preview monitor for for my video system which typically has 2 IMAG cameras, 1 VCR & 1 DVD and I want to be able to monitor/preview all four inputs on one laptop screen. Very rarely do I ever have highspeed access to the net, and I dont that would be very practicle for a live show application. Thanks, Dave Link to comment Share on other sites More sharing options...
Guest Sparks Posted February 13, 2004 Share Posted February 13, 2004 If all you want to do on the monitor is display a quad, then a normal quad and a TV card with a composite video input should do the trick! http://www.ebuyer.com/customer/products/in...roduct_uid=8976 Has a composite video input Link to comment Share on other sites More sharing options...
Guest Andyp Posted February 13, 2004 Share Posted February 13, 2004 You dont need access to the net, just use a RJ45 crossover lead direct into the laptop from the digi. Link to comment Share on other sites More sharing options...
