sanhaowangluo Posted 18 hours ago Share Posted 18 hours ago Following up on my recent post about IGMP Snooping, I wanted to share some field data regarding a performance killer that many budget managed switches hide in their spec sheets: Packet Buffer Memory. We often focus on the total PoE budget, but when deploying high-bitrate 4K or even 8K cameras, I’ve found that small buffers (under 1.5MB) on 8-port "web-managed" switches are the primary cause of random "no signal" or stuttering issues during high-motion events. My Recent Findings: Burst Traffic: When multiple cameras trigger H.265 I-frames simultaneously (e.g., a car driving through multiple FOVs), the switch buffer fills up instantly. If the buffer is shallow, the switch just drops frames, causing the NVR to lose the stream briefly. Management Lag: As I mentioned to al-yeti previously, this buffer congestion often spills over to the CPU of the switch, making the web management UI completely unresponsive until the traffic drops. The "Hull Logic" Workaround: Sometimes, strictly separating the uplinks and disabling flow control on the camera ports actually helped stability, as it forced the NVR to handle the packet pacing instead of relying on a weak switch CPU. Question for the group: > Does anyone have a "go-to" brand for 8-port or 16-port switches that actually lists their packet buffer specs and handles micro-bursts without choking? I’m trying to move away from some of the cheaper units I’ve been testing lately. Curious to hear your experiences with 4K deployments on mid-range gear. Security System Integrator | Networking & IP Camera Specialist Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47466-beyond-poe-budget-why-buffer-management-is-the-real-bottleneck-for-4k8k-multi-camera-sites/ Share on other sites More sharing options...
