Mikeski Posted November 8, 2015 Share Posted November 8, 2015 Hi I have recently bought a Risco Lightsys2 system to replace my existing system. (detectors wired independently with 6 core cable) I can see the PIRs are now EOL however the PIR's I have are standard 6 contact Risco RK500q. Any help would be really helpful. Thanks Mike Quote Link to comment Share on other sites More sharing options...
Dutchy Posted November 15, 2015 Share Posted November 15, 2015 Hi, use N/C (01) for zone 1-7 for alarm contact and zone 8 for common Tamper (for Z 1-7). You can view this is also in the installation manual ? Good luck. Termination Termination The Termination menu enables you to program the connection type used for each of the system's zones. The actual (physical) termination for each zone must comply with that selected in the zone termination menu N/C Uses normally-closed contacts and no terminating End-of-Line Resistor EOL Uses normally-closed (NC) and/or normally-open (NO) contacts in a zone terminated by End-of-Line Resistor. DEOL Uses normally-closed (NC) contacts in a zone using End-of-Line Resistors to distinguish between alarms and tamper conditions. N/O Uses normally-open contacts and no terminating End-of-Line Resistor. Quote Link to comment Share on other sites More sharing options...
Dutchy Posted November 15, 2015 Share Posted November 15, 2015 It was not quite right with Paste/cut, this is maybe more clearly. Quick Key Parameter 212 5 Termination The Termination menu enables you to program the connection type used for each of the system's zones. The actual (physical) termination for each zone must comply with that selected in the zone termination menu 01 N/C Uses normally-closed contacts and no terminating End-of-Line Resistor 02 EOL Uses normally-closed (NC) and/or normally-open (NO) contacts in a zone terminated by End-of-Line Resistor. 03 DEOL Uses normally-closed (NC) contacts in a zone using End-of-Line Resistors to distinguish between alarms and tamper conditions. 04 N/O Uses normally-open contacts and no terminating End-of-Line Resistor. Quote Link to comment Share on other sites More sharing options...
