LED Posted July 17, 2007 Share Posted July 17, 2007 Hi can any one help My chime facility doesn't seem to work. I have programmed it in the attributes to accept chime 1 on one of my door magnet Zone 7. Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted July 17, 2007 Share Posted July 17, 2007 have you turned it on too? Link to comment Share on other sites More sharing options...
LED Posted July 17, 2007 Author Share Posted July 17, 2007 have you turned it on too? Hi Dave not sure what you mean here. Do you have to assign it within the programming menu. I thought it was turned on within the zone set up area within the engineering facilities. Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted July 17, 2007 Share Posted July 17, 2007 Hi Davenot sure what you mean here. Do you have to assign it within the programming menu. I thought it was turned on within the zone set up area within the engineering facilities. asigned zone by zone, but you have to turn chime on press the chime button when in day Link to comment Share on other sites More sharing options...
LED Posted July 17, 2007 Author Share Posted July 17, 2007 asigned zone by zone, but you have to turn chime on press the chime button when in day Many thanks Dave It's working fine now. I found the instructions within the Master users file. Fancy that just the chime button... LED Link to comment Share on other sites More sharing options...
