September 3, 200718 yr comment_176955 Hi, I have an Accenta alarm and after having bought a dog, I would like to omit a zone (garage door) as part of a new program. I didnt get a user manual when I moved home last year, however the key pads on the panel look straightforward enough. The problem I have is not knowing in what order do I press them to set up a new program (set/program/re-set/omit and the relevant numbers)etc. Would anybody be able to assist? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20583-setting-a-new-program-with-an-accenta-alarm/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 3, 200718 yr comment_176956 Hi,I have an Accenta alarm and after having bought a dog, I would like to omit a zone (garage door) as part of a new program. I didnt get a user manual when I moved home last year, however the key pads on the panel look straightforward enough. The problem I have is not knowing in what order do I press them to set up a new program (set/program/re-set/omit and the relevant numbers)etc. Would anybody be able to assist? 1 Enter code. 2 Press omit. 3 enter zone number you wish to omit 4 Press set 5 leave via designated route Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20583-setting-a-new-program-with-an-accenta-alarm/#findComment-176956 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 3, 200718 yr comment_176957 Hi,I have an Accenta alarm and after having bought a dog, I would like to omit a zone (garage door) as part of a new program. I didnt get a user manual when I moved home last year, however the key pads on the panel look straightforward enough. The problem I have is not knowing in what order do I press them to set up a new program (set/program/re-set/omit and the relevant numbers)etc. Would anybody be able to assist? 1 Enter code. 2 Press omit. 3 enter zone number you wish to omit 4 Press set 5 leave via designated route Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20583-setting-a-new-program-with-an-accenta-alarm/#findComment-176957 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 3, 200718 yr comment_176960 Hi,I have an Accenta alarm and after having bought a dog, I would like to omit a zone (garage door) as part of a new program. I didnt get a user manual when I moved home last year, however the key pads on the panel look straightforward enough. The problem I have is not knowing in what order do I press them to set up a new program (set/program/re-set/omit and the relevant numbers)etc. Would anybody be able to assist? hello " Elvis " ( cool name btw ) it might be possible to set the system up with more than one part set - means you only need to press one button to set with zones omitted , but it`ll need an engineer to set this up for you. it`ll be fine using the manual omit described above but would be a good idea to have the system proffesionally serviced if youv`e been there a year and the engineer could do the re-proggraming at the same time. Angus (trying to save you money see ) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20583-setting-a-new-program-with-an-accenta-alarm/#findComment-176960 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 20, 200718 yr Author comment_178794 hello " Elvis " ( cool name btw )it might be possible to set the system up with more than one part set - means you only need to press one button to set with zones omitted , but it`ll need an engineer to set this up for you. it`ll be fine using the manual omit described above but would be a good idea to have the system proffesionally serviced if youv`e been there a year and the engineer could do the re-proggraming at the same time. Angus (trying to save you money see ) Markovitch / Angus, Just like to express my thanks for both sets of advice. The first reply has solved my problem - thanks for that. Longer term, I will be looking to get the alarm "serviced" and I will see if the engineer can sort a new program out for me. . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20583-setting-a-new-program-with-an-accenta-alarm/#findComment-178794 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
