External siren wiring
Guest ladyluck
Guest ladyluck
I am installing a new Optima G3 control panel and intend using a Chubb Delta 5 external siren but am not sure of the connections on the latter.
My control panel terminals are
T -ve tamper return
A -ve supply (0V)
D +ve supply (12V)
B -ve sound trigger
The ten terminals on the sounder are
10 str-
9 str+
8 tamp
7 tamp
6 int batt-
5 int batt+
4 siren
3 0V
2 +
1 siren h/off
Any help with connecting this up would be much appreciated.
Yow will find that its a gardtec delta and the connections are.
T Tamp R
A Tamp F And Bell hold
D Siren +
B siren -
STRB - STR -
STRB + - D
There should be a internal battery to connect to INT BATT + & -. Ignore the other
terminals.
Dave Oxendale
York based security systems engineer.
Guest ladyluck
Many thanks Dave for the information. Does it matter which way round the T & A connections go as they are just labelled Tamp on the sounder?
