Guest SoulessEye Posted April 17, 2005 Share Posted April 17, 2005 Hi everyone, once again thanks for your input. I understand your concerns here, I'm in I.T and the amount of work that's being off-shored is frightening, some of the code that comes back is very good quality but some is abysmal especially when it is to be used in validated systems. I had the Galaxy 8 panel lying around anyway (donated from a relly) and thought it would be a waste to not use it - particularly since it has such a good reputation. Thanks for the advice given, I'll persevere and hopefully the Odyssey manual will explain how to connect it to the panel. Dave Link to comment Share on other sites More sharing options...
Chris Teague Posted April 17, 2005 Share Posted April 17, 2005 Thanks for the advice given, I'll persevere and hopefully the Odyssey manual will explain how to connect it to the panel. If it does not, someone here will be happy to go through the connections & programming with you Regards Chris Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company Link to comment Share on other sites More sharing options...
black knight Posted April 17, 2005 Share Posted April 17, 2005 i,ve checked the manual - there are 5 connections a b c d s which are all itemised in the manual. with your hopefully gained knowledge from working on the test bed you should have no problem finding the right combination. ps i found the manual by doing a search for texecom oddysey sounders in google and it wasnt in any protected places so i arnt given any info that can,t be found by joe public paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company." Link to comment Share on other sites More sharing options...
Guest SoulessEye Posted April 17, 2005 Share Posted April 17, 2005 Hi Paul, thanks for that. I managed to d/l the pdf manuals for the Odyssey range, as you say they're available online as are the Galaxy manuals. Panel Set Intruder Bell Strobe Bell A (12v) B (Bell) C (Tamp) D (0v) S (Strb) Probably try: Bell Panel A (12v) +ve B (Bell) Bell C (Tamp) No Idea D (0v) -ve S (Strb) Strobe Hopefully I wont blow it up Dave i,ve checked the manual - there are 5 connections a b c d s which are all itemised in the manual. with your hopefully gained knowledge from working on the test bed you should have no problem finding the right combination.ps i found the manual by doing a search for texecom oddysey sounders in google and it wasnt in any protected places so i arnt given any info that can,t be found by joe public paul 49041[/snapback] Link to comment Share on other sites More sharing options...
black knight Posted April 17, 2005 Share Posted April 17, 2005 if you read the manual in more depth it tells you about the tamp and what /where to connect. depending on how you have been testing the galaxy it should be self obvious where it goes paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company." Link to comment Share on other sites More sharing options...
Guest SoulessEye Posted April 17, 2005 Share Posted April 17, 2005 Doh, not reading the manual properly, -ve tamper return. Ta Dave if you read the manual in more depth it tells you about the tamp and what /where to connect. depending on how you have been testing the galaxy it should be self obvious where it goespaul 49084[/snapback] Link to comment Share on other sites More sharing options...
black knight Posted April 17, 2005 Share Posted April 17, 2005 THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company." Link to comment Share on other sites More sharing options...
Guest SoulessEye Posted April 17, 2005 Share Posted April 17, 2005 Enlighten me then? 49093[/snapback] Link to comment Share on other sites More sharing options...
black knight Posted April 18, 2005 Share Posted April 18, 2005 as i am sure you know by now the tamper return is the signal the sab (BELL) sends to the c/u unit - usually a negative. if the negative is lost the alarm will indicate bell tamper paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company." Link to comment Share on other sites More sharing options...
