Guest andy31 Posted March 21, 2005 Share Posted March 21, 2005 Hi all, I have recently moved into my flat. The alarm has been working fine up until today. It is a Veritas 8 zone alarm. When I tried to set it earlier, it simply made a short beep. Whatever button I press it does the same, even if I try to reset it with my pin number first. Is there anything I can do myself to get it working again? Link to comment Share on other sites More sharing options...
breff Posted March 21, 2005 Share Posted March 21, 2005 If you have a panic button check that it is reset. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
Guest Posted March 21, 2005 Share Posted March 21, 2005 Not without the engineer code, sounds like a service timer has expired. I think youll have to get someone out to reset it for you. Or if the unit beeps 1 to 8 times and a zone light appears - then that zone is in fault when you are trying to set the system. Link to comment Share on other sites More sharing options...
