Cieska Posted August 8, 2021 Share Posted August 8, 2021 Hi peaps, On the initial set up when Honeywell Galaxy boots-up for the first time (after the reset), the options after choosing the language there is: 01 = ADT Com UK 02 = ADT Res UK 03/10 = ... (other countries) I can't find anywhere what difference is between those two first ones? Does it sets the panel to be Grade 2 (01) and/or Grade 3 (02) compatible? Or what it does? And if doesn't relates to Grade, then is it even a option on Galaxy? Tnx Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted August 8, 2021 Share Posted August 8, 2021 Your panel has specific firmware loaded for ADT. This includes a set of pre-configured options for their ARC telephone numbers and various other ADT specific settings. Option 1 is their commercial settings and 2 is for residential. Whatever option you select, you should enter all menus and ensure that they are specific to your install. Better still, use a non - ADT panel. 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 9, 2021 Share Posted August 9, 2021 (edited) 23 hours ago, Cieska said: Hi peaps, On the initial set up when Honeywell Galaxy boots-up for the first time (after the reset), the options after choosing the language there is: 01 = ADT Com UK 02 = ADT Res UK 03/10 = ... (other countries) I can't find anywhere what difference is between those two first ones? Does it sets the panel to be Grade 2 (01) and/or Grade 3 (02) compatible? Or what it does? And if doesn't relates to Grade, then is it even a option on Galaxy? Tnx Just pick any and delete the account details after so it isn't constantly trying to communicate somewhere Although as GG said use non adt panel , or try and update firmware Edited August 9, 2021 by al-yeti 1 Quote Link to comment Share on other sites More sharing options...
Cieska Posted August 9, 2021 Author Share Posted August 9, 2021 (edited) Yech. It's FW v6.10., I'd anddoes complain about line error. There is an option to disable line interface, also it has some serious bugs, or it's *****up or I'm maybe missing something howto sett it up. For example the keypad doesn't allow to enter the code to unset the system during the entry time, so when alarm kicks in, o ly then it accepts key entries. Im just now in situation to find out if I can do firmware without buying any special software. Edited August 9, 2021 by Cieska correction Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 9, 2021 Share Posted August 9, 2021 thats not a bug its a default feature. Its an option. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Cieska Posted August 9, 2021 Author Share Posted August 9, 2021 Oh ****. Is this related with 51.03.1 Abort Time? I have had time to understand real meaning and use of it. Or else? thanks for info as i was banging my head in to the wall. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 9, 2021 Share Posted August 9, 2021 no thats different in the dd243 / bs8243 setting change restric keypad. By default in the UK your not permitted to unset with a pin code 'if' using prox fobs 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted August 9, 2021 Share Posted August 9, 2021 6 hours ago, Cieska said: Yech. It's FW v6.10., I'd anddoes complain about line error. There is an option to disable line interface, also it has some serious bugs, or it's *****up or I'm maybe missing something howto sett it up. For example the keypad doesn't allow to enter the code to unset the system during the entry time, so when alarm kicks in, o ly then it accepts key entries. Im just now in situation to find out if I can do firmware without buying any special software. Basically you need to learn about the panel , bugs is another issue 1 Quote Link to comment Share on other sites More sharing options...
Cieska Posted August 9, 2021 Author Share Posted August 9, 2021 2 minutes ago, al-yeti said: Basically you need to learn about the panel , bugs is another issue Thanks for letting me know. Not sure if I have to crate a new topic but will try to not. I have go other question: Should the number on the fob and what reader sees be the same? In my case it's not and fob doesn't do much when programmed in and presented to the reader, for example to do timed set. I have some glitches on the system. So its hard to learn without knowing how the system must really act in first place. Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted August 9, 2021 Share Posted August 9, 2021 No, that's the MAX reader number printed on the black fob. The number scanned by the keyprox is correct. You need to configure the users menu to link the MAX tag to the setting function if you want to use to set the system - you then need to hold the tag to the reader until the setting countdown shows on the display. 1 Quote Link to comment Share on other sites More sharing options...
