Combined Wired Shock and Contact Sensor
21 minutes ago, Sparkypenguin said:
I've decided to buy and test a flush mounted contact to see if I can fit into the frames.
Probably an Elm-6QFC(RD) and/or RFT-RD as the metered tails on the pre wired one may be too short.
look very carefully how big a gap you have between frame & door to fit the top of the nylon contact in place
the stainless steel capped ones are thinner & more robust if they rub together
