SW1070 Panel: Tamper or Sensor Triggered Alarm?
1 hour ago, Eugene's DIY Den said:
Can I use a double knock option on the same zone to only trigger an alarm after several operations of the PIR?
HKC have a wireless Dualtech now its much better for hostile environments like sheds and garages
  • Like 1
  • Upvote 1
3 hours ago, sixwheeledbeast said:
You can, but you shouldn't.
agreed its an awful option and should never be used
If its wired use a dt, if rf use the hkc dt or better still dont use space protection in a shed
  • Upvote 1
Doesn't work well for fa
Hkc pir won't trigger as fast as normal standard pirs might be better option or the wireless as said above
  • 2 weeks later...
What's the approximate line-of-sight range (for the radio signal) of those?
Its the same as the rest of the wireless kit
"Developed by our in-house R&D team, the detector has exceptional RF range allowing it to be positioned in the trickiest of locations"
https://www.hkcsecurity.com/Other/hkcsecurityCOM/Public Downloads/Ireland/Intrusion - Wireless/RF-PIR-DT.pdf
I have tested extreme range of this, on a farm environment it was about 1km. At the time wish I had the powered mesh unit in theory I could of got 8, I will at some point do range testing on the leading manufacturers, but that needs a beach to be fair
