Relace adt panel and keyboard recommendations please
Honda3
What makes you think the fault is in the 4 inches that you cut off? Where does it run from to? By that, I mean does it run under the floor or around the skirting board, under the carpet etc?
I read it as put on a fly lead.
2 hours ago, Honda3 said:
 Ive cut 4 inches of the kepad wire and reconnected it.
It could be interpreted that way I suppose, but I read it that he removed 4" of cable off the keypad cable.
  • 2 weeks later...
Hi thanks for the replies. I did that because the keypad was next to cellar door and it kept hitting it when opening, not ideal but was like that when i moved in. Its been ok since i cut wire but most of the time the fuse last  months so not sure if thats fixed it.
I Do realy want to replace the kepad because some buttons have become unresponsive. Any suggestions just for the keypad would be great thanks.
@Honda3
find a local tame alarm man, get them to price via email to replace the controls, battery & external bell.
they'll measure all the cables & currents if they've 1/2 a brain...
I'd assume your cables are stapled under the carpets ?
Replace the fuse & tread on every inch of carpet where a cable might be lurking ?
  • Upvote 1
