Yousuf Posted March 17, 2021 Share Posted March 17, 2021 I have a Veritas 8. One of the PIR sensors does light up but it doesnt activate the alarm. So i'm thinking it needs replacing? Is this simple to do? Any guidance would be appreciated Thanks Quote Link to comment Share on other sites More sharing options...
PeterJames Posted March 17, 2021 Share Posted March 17, 2021 Not necessarily the detector, it may be that its not programmed correctly, it may be that its linked out in the panel, or a cable fault. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 17, 2021 Share Posted March 17, 2021 13 minutes ago, Yousuf said: I have a Veritas 8. One of the PIR sensors does light up but it doesnt activate the alarm. So i'm thinking it needs replacing? Is this simple to do? Any guidance would be appreciated Thanks What PIR is it , main thing is not shorting the power out and blowing a fuse As above it could be that your cable is damaged , so first thing would be to get the cover off, and see with a meter if power is available at the power terminals inside the PIR Then go down the PIR replacement route Quote Link to comment Share on other sites More sharing options...
