Texecom Premier Elite 24 - Surface Contact Wiring
Macca80
30 minutes ago, sixwheeledbeast said:
You need resistors for your contacts or contacts with resistors built in would be best.
Something like SC570/WH/MULTI for example.
They don't provide resistors in any Texe stuff now.
Thanks I'd seen the SC570 earlier and have now ordered. Thank you both for your help it's much appreciated.
Edited by Macca80
On 17/03/2021 at 18:33, sixwheeledbeast said:
Read instructions carefully cut the wrong links and you'll likely need another
Hi, I've recieved the SC570 contacts today. Am I right in thinking that I need to remove both Red B links? Thanks
If that's what colours the instructions say? I haven't got one to hand, you would normally only cut one coloured loop from each row for one device IIRC.
As al says if you are careful and cut at the top of the loop you could solder the link back closed again, if you get the wrong link.
NC is a spare terminal (no connection)
I've attached the image from the manual. 4k7 and 2k2 both seem to be a red link as I'm understanding it.
