paulbaker1954 Posted February 28, 2021 Share Posted February 28, 2021 When changing the 500mA aux fuse on my panel I disconnected the mains power and battery but when I pull the fuse the bell box still goes off on its battery. How do I stop the bell box going off when working on this panel as I have particularly grumpy neighbours. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 28, 2021 Share Posted February 28, 2021 alarms have self activating bells, when the power is removed from the unit, it sounds (powered by its own battery) in most case if you don't want it to sound you get the ladder out & disconnect the battery... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
paulbaker1954 Posted February 28, 2021 Author Share Posted February 28, 2021 (edited) 37 minutes ago, MrHappy said: alarms have self activating bells, when the power is removed from the unit, it sounds (powered by its own battery) in most case if you don't want it to sound you get the ladder out & disconnect the battery... Yup that’s what I assumed!!! Just hate doing that as the sounder hammers my ears when you lift the bell box cover. You pros must use some serious ear defenders Edited February 28, 2021 by paulbaker1954 Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 28, 2021 Share Posted February 28, 2021 It shouldnt go off if the battery in the panel is ok, and why do you need to replace the aux fuse? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 28, 2021 Share Posted February 28, 2021 2 hours ago, paulbaker1954 said: You pros must use some serious ear defenders err no.... Which is probably why I'm going deaf ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
paulbaker1954 Posted February 28, 2021 Author Share Posted February 28, 2021 51 minutes ago, PeterJames said: It shouldnt go off if the battery in the panel is ok, and why do you need to replace the aux fuse? Cos it blew when I accidentally shorted the + and - on a PIR Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 28, 2021 Share Posted February 28, 2021 Okay most people dont know why the fuse blew, blown fuse is a symptom of a problem in many cases Quote Link to comment Share on other sites More sharing options...
Andyha Posted March 3, 2021 Share Posted March 3, 2021 Just power the bell/siren direct off the battery while you work on the panel. This will hold the SAB silent. There will be a short blip (duration of however long it take you to remake the connection) I normally prewire a common neg and only disconnect and reconnect the positive. Use a lead with a spade terminal one end and an insulated crock clip the other (or crocks both ends) Quote Link to comment Share on other sites More sharing options...
paulbaker1954 Posted March 3, 2021 Author Share Posted March 3, 2021 5 hours ago, Andyha said: Just power the bell/siren direct off the battery while you work on the panel. This will hold the SAB silent. There will be a short blip (duration of however long it take you to remake the connection) I normally prewire a common neg and only disconnect and reconnect the positive. Use a lead with a spade terminal one end and an insulated crock clip the other (or crocks both ends) Perfect thanks bud Quote Link to comment Share on other sites More sharing options...
