Paddymch Posted February 23, 2021 Share Posted February 23, 2021 Hi All, DIY'er here - no alarm experience at all - but developer background and setup, wired and configured HIK IP CCTV system over 18 months ago. I currently have a Texecom Veritas (excel - I believe) alarm with a Texecom pstn dialler. I'm getting rid of my landline and have recently switched to fibre - what options do I have in terms of a GSM dialler (was looking at a pyronix V2) or is there a VOIP option I should consider? I'd prefer to leave the current alarm unit and just change the dialler - if I could - any advice would be great, even if it's only an avenue to investigate. Was considering sourcing a 2nd hand Pyronix GSM dialler on eBay... any thoughts on that approach? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 23, 2021 Share Posted February 23, 2021 anything non pstn is an improvement. Im not a fan of gsm diallers i prefer a polled signalling device Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted February 24, 2021 Share Posted February 24, 2021 2 hours ago, Paddymch said: Hi All, DIY'er here - no alarm experience at all - but developer background and setup, wired and configured HIK IP CCTV system over 18 months ago. I currently have a Texecom Veritas (excel - I believe) alarm with a Texecom pstn dialler. I'm getting rid of my landline and have recently switched to fibre - what options do I have in terms of a GSM dialler (was looking at a pyronix V2) or is there a VOIP option I should consider? I'd prefer to leave the current alarm unit and just change the dialler - if I could - any advice would be great, even if it's only an avenue to investigate. Was considering sourcing a 2nd hand Pyronix GSM dialler on eBay... any thoughts on that approach? Any gsm dialler will do, Best to get a cheapmonthly sim with unlimited txt , most don't remember to top up or when your system goesad it send lots of txt and uses up credit anyway 1 Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted February 24, 2021 Share Posted February 24, 2021 Ebay is a good way to get rid of junk so caution is advised. System is basic so doesn't have any options for IP addons. If your keeping the system then you can only go for universal off the outputs/bell trig type devices. You could try some sort of ATA but your reliant on compatibility and good uptime for all the kit the message goes through. At least a GSM dialler would be powered from the system so only have to think about signal and phone costs then. Polled signalling is most secure but out of the realms for DIY. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted February 24, 2021 Share Posted February 24, 2021 Agreed on monthly or at least some PAYG plan where you can access online if you go that way. Bear in mind they cut sims off if you don't make outbound services regular. Quote Link to comment Share on other sites More sharing options...
