saguy Posted December 28, 2020 Share Posted December 28, 2020 Hello. I have two use cases for the SC-W contact/shock sensor. 1. Using shock sensor and magnetic sensor on my skylights to alarm when skylights are open or attempted break-in. My understanding is that the dip switches are: M - ON, S - On, T1 - Off, T2 - Off. 2. Using the inputs on the SC-W to connect my normally closed perspex burglar bars which essential have a wire running through them to determine if it's been cut. I imaging that one end of the wire goes to T1 terminal and the other to COM. Then dip switches are: M - Off, S - Off, T1 - On, T2 - Off. Then I'm also not sure what the correct mode would be, Hybrid/Auto? etc... Anyone have experience or guidance on this? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted December 28, 2020 Share Posted December 28, 2020 Sorry i dont use texecom for anything 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Amps Posted December 29, 2020 Share Posted December 29, 2020 Over complicated crap 1 Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted December 29, 2020 Share Posted December 29, 2020 (edited) 1. Correct 2. Correct The correct Ricochet Device Mode will be selected when you learn the device onto the receiver. Edited December 29, 2020 by pcaouolte 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 29, 2020 Share Posted December 29, 2020 3 hours ago, pcaouolte said: 1. Correct 2. Correct The correct Ricochet Device Mode will be selected when you learn the device onto the receiver. So y have manual selection , shouldn't they just call it battery mode as realistically that's what it's for it seems Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted December 29, 2020 Share Posted December 29, 2020 53 minutes ago, al-yeti said: So y have manual selection. A few devices have had problems in the past, being able to change the mode provided a workaround. Usually you just learn on the device and leave the device mode which is selected by the device. Some people like to dabble with changing the mode which can improve battery life at the cost of reduced functionality. 1 Quote Link to comment Share on other sites More sharing options...
saguy Posted December 29, 2020 Author Share Posted December 29, 2020 4 hours ago, pcaouolte said: 1. Correct 2. Correct The correct Ricochet Device Mode will be selected when you learn the device onto the receiver. Thanks. Could one theoretically use M, S and T1 together? I see nothing that says otherwise in the manual. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 29, 2020 Share Posted December 29, 2020 1 hour ago, pcaouolte said: A few devices have had problems in the past, being able to change the mode provided a workaround. Usually you just learn on the device and leave the device mode which is selected by the device. Some people like to dabble with changing the mode which can improve battery life at the cost of reduced functionality. Cool, you in trade? But not in trade , apply ..... Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted December 29, 2020 Share Posted December 29, 2020 4 hours ago, saguy said: Thanks. Could one theoretically use M, S and T1 together? Yes, and T2 if you want a tamper input. A possible problem is that these all appear as one zone, I don't know if South African standards would permit that. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 29, 2020 Share Posted December 29, 2020 3 minutes ago, pcaouolte said: Yes, and T2 if you want a tamper input. A possible problem is that these all appear as one zone, I don't know if South African standards would permit that. South Africa have a zone connection to an Uzi so no problem Quote Link to comment Share on other sites More sharing options...
saguy Posted December 29, 2020 Author Share Posted December 29, 2020 7 minutes ago, pcaouolte said: Yes, and T2 if you want a tamper input. A possible problem is that these all appear as one zone, I don't know if South African standards would permit that. Thanks for that. I'm still learning and appreciate the info. What makes T2 special then? Is it just that if it is "triggered" the alarm will show it as a tamper? 3 minutes ago, al-yeti said: South Africa have a zone connection to an Uzi so no problem What is an Uzi? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 29, 2020 Share Posted December 29, 2020 Just now, saguy said: Thanks for that. I'm still learning and appreciate the info. What makes T2 special then? Is it just that if it is "triggered" the alarm will show it as a tamper? What is an Uzi? Uzi 9mm? https://youtu.be/CGPIVJOb788 Quote Link to comment Share on other sites More sharing options...
saguy Posted December 29, 2020 Author Share Posted December 29, 2020 3 minutes ago, al-yeti said: Uzi 9mm? https://youtu.be/CGPIVJOb788 Oh... hahaha... don't be silly. It's connected directly to a hatch which releases a 2 litre coke and kfc to bribe the police to provide assistance. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted December 29, 2020 Share Posted December 29, 2020 58 minutes ago, saguy said: a 2 litre coke and kfc to bribe the police to provide assistance. 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted December 30, 2020 Share Posted December 30, 2020 Seems we might get along, on the trade thing I'm sure they take 33 in a 30 just as serious Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted December 31, 2020 Share Posted December 31, 2020 On 29/12/2020 at 18:00, saguy said: Oh... hahaha... don't be silly. It's connected directly to a hatch which releases a 2 litre coke and kfc to bribe the police to provide assistance. Your gonna fit in quite nicely here! Quote Link to comment Share on other sites More sharing options...
