Paul Doyle Posted December 15, 2020 Author Share Posted December 15, 2020 thanks galaxy guy the administrator what is the password bud cheers paul sorry it serial connection on the 232 port thanks Quote Link to comment Share on other sites More sharing options...
Paul Doyle Posted December 15, 2020 Author Share Posted December 15, 2020 using a old dell windows system for the serial port on back it was stuck on the page saying loading database i have system restored back to earlier point a will give it a go and i appreciate your time Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 15, 2020 Share Posted December 15, 2020 The default is 'manager' and 'password'. If you open up the comms manager in the system tray and select the com port you have set up, ensure that com port has the correct settings for your panel. If your panel is at default, it will be direct at 9600 baud. If you've modified the internal RS232 speed, then you need to match the settings you have set. Also, the database is a MSSQL, so RSS relies on the db server being up and running. Quote Link to comment Share on other sites More sharing options...
Paul Doyle Posted December 16, 2020 Author Share Posted December 16, 2020 hello galaxy guy I followed the above what you suggested it says front shell is not connected to Comms server connecting to the panel Is not possible Regards Paul Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 16, 2020 Share Posted December 16, 2020 2 minutes ago, Paul Doyle said: hello galaxy guy I followed the above what you suggested it says front shell is not connected to Comms server connecting to the panel Is not possible Regards Paul Did a pop-up box saying something like http://localhost come up ? If it does, you need to change the word localhost to 127.0.0.1 Some Windows installs seem to have issues with RSS. It will not work if MSSQLSERVER has been installed previously. Quote Link to comment Share on other sites More sharing options...
Paul Doyle Posted December 16, 2020 Author Share Posted December 16, 2020 I got a new dell today driving me nuts I no its something stupid i will start it over again i am on the main screen com 5 galaxy icon top half box below server uknown listening Quote Link to comment Share on other sites More sharing options...
Paul Doyle Posted December 16, 2020 Author Share Posted December 16, 2020 cannot connect to comms server http:127.0.01:8888/disco/?handler =common service once again thanks Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 16, 2020 Share Posted December 16, 2020 Make sure you get the loopback IP address correct it's. http:127.0.0.1:8888/disco/?handler =common service Not sure if you just had a typo above missing a dot. It seems newer versions of Windows are not resolving localhost back to the loopback address and RSS requires that. Quote Link to comment Share on other sites More sharing options...
Paul Doyle Posted December 16, 2020 Author Share Posted December 16, 2020 127.0.0.1 Driver={SQL Server};server={.\sqlexpress};Trusted_Connection=no;uid=sa;database=Dimension; galaxy is it windows 10 or just newer versions of windows cheers bud Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 16, 2020 Share Posted December 16, 2020 46 minutes ago, Paul Doyle said: 127.0.0.1 Driver={SQL Server};server={.\sqlexpress};Trusted_Connection=no;uid=sa;database=Dimension; galaxy is it windows 10 or just newer versions of windows cheers bud I've not gone back to older versions to check, but did start seeing it in W10. Quote Link to comment Share on other sites More sharing options...
